Remote Engine Shutdown
CarlosRam
Cummins 5.9
How do I turn off the engine by interrupting some ignition switch wire in the RAM 2500 08 using relay? It's possible?
C
CarlosRam
Cummins 5.9
I need to turn off the engine when the switch is in the ON position
C
CarlosRam
Cummins 5.9
I need to turn off the engine when the switch is in the RUN position
justin13703
MD
There are two ignition wires coming off of the ignition switch. You will have to interrupt them both with relays, possibly by wiring them up to the normally closed terminals, so that activating the relays will open the ignition circuits and shut the truck off. You have to pay attention to amperage draws while doing this though.
C
CarlosRam
Cummins 5.9
Hi justin13703. Do you know the color of the two wires?
justin13703
MD
Ignition 1 should be pink/white and ignition 2 should be pink/green.
C
CarlosRam
Cummins 5.9
I was able to turn the engine off by interrupting the wires pink / white and violet / brown.
  • Ignition Switch RAM 2500 08.pdf
Orca
