Replacing factory radio, adding backup camera?
cuevrojamez
What have you guys done in replacing the factory radio?
Curious what the single DIN looks like vs. the double DIN.
Also curious if anyone has added a backup camera.
07MegaCabRam
Chandler, Arizona
6.7L CTD
I did a double din, did some body work to my bezel and installed a $20 HD camera in my plastic bed cap..
Well, this was my 2007..
Then I did a hydro dipped for a friend.. same set up..
Ceri
I'd highly recommend narrowing in on a double din. The factory opening looks funny with a single din unit, and you'd have a hard time with a backup camera if you can even find one that does a camera.
justin13703
MD
If you do a double din, you will either have to modify your current dash panel by cutting it, or you will have to get a whole new center dash piece out of a truck that had factory navigation.
The radio in your truck is a din and a half size. So you can't install a double din without cutting or replacing your dash panel.
The easiest, but most expensive way, is replacing the dash piece. It will snap right in and your double din will install right into it. The next way, which is cheaper, is to cut your dash panel and use the metra dash kit that comes with the piece that snaps over where you cut. Then install your double din. The other way which is the most work, is to cut the dash panel and use fiberglass or some kind of filler and basically treat it like body work on a car, smooth it out and paint it.
Ceri
I haven't installed one of these, but I was surprised to learn that metra now does double din bezels for the 02 to 05, so I looked it up and they have one for 30 bucks for the 06 to 08s too. It looks like it mounts on top of the factory bezel and looks pretty clean, but you do chop out some plastic on the stock bezel. I know it used to be that you had to custom build one, but maybe not anymore?
http://www.crutchfield.com/S-iRhu7sPvfA5/p_120956528B/Metra-95-6528B-Dash-Kit-Matte-Black.html
justin13703
MD
Metra 95-6528B Dash Kit (Matte Black) Fits select 2006-09 Dodge Ram trucks — double-DIN radios at Crutchfield.com
That's the 2nd one I was talking about. This is the dash kit that Ram Em has in his truck.
justin13703
MD
What did you guys do to retain the chimes? I'm asking for an '08 4.7 with a basic stock radio.
The chimes are generated by a device built into the gauge cluster of the truck.
But on other vehicles where chimes are generated through the radio, the correct harness for the vehicle will include a box that interfaces with the vehicle's data system and recreates the chimes either back through the speakers like stock, or through a speaker built into the box.
F22-Raptor
Earth (err... really Toronto, Canada)
4.7L
Thank you, thank you, thank you!!! I've been trying to figure out how the chimes worked. All along I was under the impression that it was through the radio.
justin13703
MD
Most newer vehicles, gm for example, do run the chimes through the driver side speaker. But on our trucks its a little simpler.
Jerred17
