Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I have a quick question, I was cleaning my truck and noticed...I guess these are
Rim chips or scratches??? At any rate what is the best way to remove? I tried wiping it
with a clothe but didn't work.
It looks like wheel corosion. Is that what you are refering to? If so, you can try a product called "Never dull". It works wonders with polished surfaces!
^^ x2 never dull works great on surface oxidation. I used in on mine.
If it doesn't come off, it is probably wheel corrosion that is underneath the clear coat, it was hard to tell in the pic if that was it. If it is, it will have a whitish look to it. I had that bad on the outer lip of my chrome clads.
sorry will take a better pic but I will try what you said.....btw yes I was referring to the dark spots on the rims.....will let you know....thank you!!
