RPM surge when coasting
TurboRamNJ
NJ
5.7 .... for now
Ok, so on decel my rpms surge, they will jump about 400 rpms and drop to normal. 128k miles, and it just started doing it. I noticed that my AFR's will hang around 15-16 when this happens. Since Decel fuel shut off is active, it should be zero (lines). When it is zero, it decel's as it should. It happens a few times a day, sometimes worse than others. Anyone else have this issue? I was / am leaning on a leaky injector.
caulk04
Are you seeing the trans downshifting? The tune might just be throwing in a little fuel to match rpm and soften the downshift.
TurboRamNJ
TurboRamNJ
NJ
5.7 .... for now
Nope, same tune thats been in it for 3 years. I even reloaded the tune "just in case" lol and no change. Im feeling like this is a mechanical issue.
Daw14
Check your intake manifold bolts , they may be loose.
