Running Rich
Shadow06
Winnipeg MB Canada
My 2017 hemi is running rich & want to know how to fix the solution
my exhaust tips are black & my x-pipe had black carbon on it.
add ons are
ColdAirIntake
LongTubeHeaders
TrueDual Exhaust System.
Tach_tech
5.7L HEMI
Some carbon build up on the tips and X pipe doesn’t necessarily means it’s rich. Has your fuel mileage changed? If you’re a spirited driver that can also contribute to it.
Do you have access to a scan tool that can monitor fuel trims?
S
Shadow06
Winnipeg MB Canada
Can smell the exhaust though its strong, & no I haven’t noticed that.
A scan tool I dont have but most likely will get one
Tulecreeper
Sthrn AZ
Spirited driver? That's a new one. :driver:
Jake103
Minnesota
Get a scan tool and check out your long and short term fuel trims. Also moniter them live. If you get a good one you can usually command injectors on and off as well as other things to verify. Hard to say just by what you described. Also see if you have any misfire codes along with rich or lean codes, than you can go from there.
Riccochet
Somewhere around Charlotte
2020 2500 Laramie Longhorn
Get your injectors serviced. May not be atomizing properly. If a few are just squiring fuel it's not going to burn.
