Shift knob.
trikeffex
Hammond,La
2013 sport ram
Hey guys,
Its nothing drastic but i have a similar shift knob on my Polaris Rzr's and Ranger and figured id try 1 on my truck and if it didn't work then im only out $14 and id have a backup for 1 of my sidexsides.It came with 4 inserts and used the smallest 1 and it snugged down nice and tight.Heres a few pics.
It may not be for everyone but i like it!!
Charles
RCFiddyOne
Not bad. Nice work. I need to post mine up.
Sybil
I like it but it seems a little high.
BlkRamRt
SoCal
HEMI 5.7
i agree it looks a little high but the skull makes up for it. looks good.
trikeffex
trikeffex
Hammond,La
2013 sport ram
Yea it does sit up a little high as ive mainly noticed it when driving since i use to rest my arm on the center console and my hand on the shiftknob.I refuse to pay a crapton of money just for a shiftknob so ill keep this till i get tired of it then throw the stocker back on or find a new 1.If i knew that i never plan on putting the stocker back on then id just cut down the shaft to make it shorter but i just can't make myself do it.
Charles
trikeffex
trikeffex
Hammond,La
2013 sport ram
Ok a small update guys.I took the Knob back off and decided id try to drill it out a bit to get it to go down further.The skull is basically just resin so its soft enough to drill through easily.You really dont have to worry about weakening it much because the drilled resin in the skull itself is just for clearance as it tightens down on the bottom.
I think it looks much better now.
This is the hole that i drilled:
Here it is installed again:
Charles
Lhemi
OKC OK
6.7 Cummins Turbo & Hemi 5.7
Agree ^^^^ that looks a lot better! I might have to try this, but maybe with a custom paint.....
Nice job!
Cowboy345
Kentucky
Not my style but I can't definitely appreciate the custom factor. What's them wheels on your SxS?
trikeffex
trikeffex
Hammond,La
2013 sport ram
THE wheels are NO Limit Venoms powdercoated white with positive machining on the edges...
Charles
