Side mirror disassemble for paint
Slickity79
Hello all this is my first post. I recently had Retroshop smooth and paint my textured mirror caps to match the truck. I have a 2012 Ram Express in Mineral Grey Metallic. Here is how to remove the caps:
1. Move the mirror to point down as far as it will go so your fingers will fit between the top of the mirror and the plastic housing.
2. Use both hands and grab the top of the mirrors and firmly pull towards you until it pops loose.
3. Pull the top of the mirror towards you to release the bottom hooks then pull up to remove it. You don't have to disconnect any wires to remove the cover, just turn the mirror facing down and the housing will hold it.
4. Remove the three torx head screws, pull the plastic retainer towards the outside of the of the housing and the cover will come loose. You will have to move it around to get it completely off. I've attached some pics that will hopefully help out.
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
Ricky......you tease!
Post up the pics of 'em done too! LOL
Slickity79
Slickity79
Here are some before and after pics, still haven't been able to post pics other than with attachments. The first two are before and the last two are after. Enjoy!
Slickity79
Slickity79
Also, this truck came with the auto-dim rear-view mirror and just power/heated side mirrors. I bought a set of power/heated, side turn signal with auto-dim mirrors from a guy on ebay. They were also black textured, and when I put them on my truck the auto-dim part worked but the turn signals didn't. So, since the rest of the housing is the same on both mirrors I decided to get the original caps painted. I really like the auto-dim and the way these look painted without the turn signals.
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
Thanks for the extra pics Ricky!
ATOM
nice! in the process of doing the same swap. who buys that color :crazy:
Terry2014RAM
OKC
On Step 2, mine just separates the tilt motor, finger half from the ball half at the top and it is very difficult to put them back on.
Anyone know a way to get the mirror off without separating the tilt motor? I tried this weekend and never got the mirror removed but pulled hard enough to separate the tilt motor top half.
Thank you
Cableman
Longisland
Thank you
Sometimes this happens, can ruin that motor too. I move mirror all the way down then in and use a flat head screw driver to pop one of the clips out and then pull down to release the other.
Its just hard to find where to stick the driver at 1st unless ya know how these things work.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
The 2009 - 2012 exterior mirrors come apart much simpler then the 2013 & newer
My 2009 Dodge Ram was parked on the street, a truck or car with lumber or something else sticking out, struck my mirror, honestly, it could have been punk teenagers using a baseball bat.
Tray Burge
On the porch
That's a good looking truck my friend!
best color in the world too, but I may be a little biased? lol
share some better pictures if you have them.
My Granite Crystal 03 Hemi here.
Terry2014RAM
OKC
I have tried that but with the ridge outline on the mirror part I don't see any way get a screw driver in between the mirror and motor clip to un-clip it. Do you know where the best place to put the screw driver that will prey it apart?
Also when I folded it back to get at it I must have cut a wire because my driver mirror no longer tilts down in reverse or recalls the mem position.
