Slant six questions
D150dude
Ontario,Canada
I have an 81 with the computer on the air breather, I haven’t used my truck in a couple years so I wanna get back into it. I would like to ditch the computer and go back to a simpler hassle free ignition, what would be the best set up? What to do I have to order and the best place to order from?
pacofortacos
Basic electronic ignition with a vac. advance distributor is simple enough.
turkeybird56
Central Texas
^^^^ Ditto ^^^^^
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
between summit racing and Rock auto, I get most of my car projects done without a major issue.
Dodge 1500 4X4
Rochester, NY
X2 with Summit and Rock auto, also check the distributor drive gear, Its nylon and is known to sheer, Love the Slant six!!!!
TopHat
3 x 1985, 1992, 1981
I used a carb, distributer and ignition box from a 1973 tuck. The upgrade to a "super six" 2bbl carb is worth it if you can find a manifold reasonably. Either way might need to do some carb jetting. Rock auto or local auto parts store should be fine.
