Sled deck lighting
PommyRam
bozeman
hemi 5.9, cummins 6.7
Hello, I have a couple of electrical questions -
anyone seen a 6pin connection with this configuration? Its up front in my truck bed.
the trucks is a 2016 3500 Laramie. the chap i bought the truck from used it for his slide in camper so i presume it has something to do with that? the truck also has a 7pin trailer connection in the bed at the back (by the tail gate)
Im about to weld up a sled deck for it and want to have running lights, turn signals, winch and some bedlights for under the deck.
If i came off the 12v power pin on the 7pin trailer connection to a switch then onto the bed lights, am i right in thinking no power will b drawn with the switch off? I would be nice to do this for the winch too but I doubt it would have enough power to run the winch.
Administrator
That 6 pin in the bed was probably for the slide in camper.
The +12V in the trailer 7-pin is fused right from the battery at 30 amps. That's plenty of power to run some LEDs or recharge the brake battery but not enough for a winch. You'll either want a battery on the trailer for the winch or need to run wiring big enough to handle the current from the truck battery
Scott S
Southwestern Ontario
For the winch you can use the light power from the connector as a trigger for a relay. Then run a fused/ load protected cable from the battery to the rear through the relay. This would power up the winch only when the lights are active.
OasisNinjaBat
