ChrisGUGA
Has anyone else experienced this?
I get a slight grinding/vibration through the steering wheel when turning right or left, similar to the very slight vibration you feel through the steering wheel from the engine while accelerating.
I have Bilsteins now set at 2.1, rear 1.5" coil spacers, and a 1.5" zone body lift. 35x12.50r20 Toyo ATII extremes on stock wheels with 10mm hub and wheel centric motorsports tech wheel spacers.
I didn't put the rotor "locks" or "holds" or whatever back on the lugs when I reinstalled the brake rotors. Could this cause the brakes to rub slightly in turns?
I've retorqued everything and everything was to spec except the sway bar end links. I had to retighten them, but that didn't solve the problem.
PS: Anyone know if the Movotech UCAs come greased? I see the grease zerks, but never added any grease.
Thanks!
Thanks!
