Travelin Ram
- Jan 8, 2020
- 1,840
- 2,984
- 2022
- 6.4
Preamble- from my inspection it seems the 1500 and HD trucks for 2019 use different mountings for side steps, so this thread applies to HD specifically. (Classics might be the same, I haven't checked)
Issue 1: Today I'm under the truck closing up the taped over holes in the rockers, and I noted there are bolts missing from the front mounting bracket of my factory installed side steps. One bolt rather than two. Left and right sides the same way. Not consistent with the installation instructions I downloaded from the Mopar site, and not consistent with other trucks I examined on a dealer lot today- other trucks had two bolts. So that's definitely got to be dealt with.
View media item 28687
Issue 2: Looking a little further, I realize there's a whole other set of mounting holes in the rocker panel AND in the step, in the center position. My steps only have brackets at the front and rear, not in the center. Here's where I'm looking for feedback.
-The instructions for installing cab steps from the Mopar Accessories site clearly show 3 brackets on everything that fits 4 doors
-I found two trucks on the lot with cab length steps like mine, and they are missing the center bracket as well.
-I found two trucks with the wheel to wheel steps that extend behind the cab, and those DO have the center brackets mounted.
View media item 28686View media item 28688
So, my question is, should I roll into the dealer and insist on the center bracket being installed? Or is mine just like all the rest, and the documentation is wrong? I have to take it in anyway for the missing bolts as well as a couple of other things I've found. If it matters, these were on the factory sticker so I'm assuming bolted on at Saltillo and not the dealer.
Thanks for your advice.
