So I had an idea....
Rzrman328
The treeline
Before I go any further......It works lol.
So I get bored and try random **** and so I already have led pods installed in the rear. Those are running off my trailer harness to come on in reverse only.
Before I had wired them up that way I had toyed with the idea of having them come on with my cargo lights but really wanted them to come on with reverse mostly.
So getting to it.....tonight I tapped the cargo light while still having them tapped into the trailer harness and these are the results:
When in reverse illumination occurred from:
Reverse lights, led pods and cargo lights.
When I push my cargo light button such illumination occurs:
Reverse, led pods and cargo lights.
And now the best part...when I unlock the truck:
Heads, reverse, cargo and led pods light up.
Like I stated first sentence....it works lol
Any wiring gurus see any future issues?
R.L.K.
Bristol , Tn.
Do you have an in line fuse for the pods on both power sources ?
R.L.K.
Bristol , Tn.
For the cargo lt power source , did you get power at the push button by the dial , or @ the 3rd brake light or else where ?
R.L.K.
Bristol , Tn.
No but those can easily be thrown in.
Throw'em in for peace of mind?
I would , this way if an issue with the pods caused a short it wouldn't blow fuses for reverse lights and cargo light , and would make troubleshooting much easier .
R.L.K.
Bristol , Tn.
So long as the additional power draw on the reverse and cargo circuits arn't causing any messages or light out cautions it should be fine .
R.L.K.
Bristol , Tn.
Subscribed . I like this idea !
Rzrman328
Rzrman328
The treeline
Nope, all is good.
I was a lil surprised no messages showed lol.
what size inline fuse should I go with?
R.L.K.
Bristol , Tn.
Nope, all is good.
Look on the pods they should have an amperage rating on them . Just multiply that by the # of pods you have and install one near the pods on each power source in line .
If they are LED the amperage will be very low .
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
if there's any draw issues, just use the cargo light tap as a relay signal and run a 12V line (from battery or other constant power) and wire in a Bosch type relay.
BlownGP
Houston/Baton Rouge
So in other words your truck looks like a space ship when it the un lock button? hahah
That's one thing I wish they made is brighter cargo lamps.
GoatLocker
Cummins 6.7
Perfect for when someone is tailgating (or has their brights on). I've used my cargo light for this, but your setup will be much more effective.
R.L.K.
Bristol , Tn.
I've been thinking of installing a lightbar or pods for additional lighting for the backup camera kit I installed , and I like the idea of yours also having it operating with the cargo light button for when I'm straping down the boat at night .
BlownGP
Houston/Baton Rouge
This is what they get....ha..
Man, I like that idea of wiring it to the cargo light so when you hit it the pods come on.
How did you route the wiring to the cargo light? You go inside the cab?
turboguy327
You need to be careful when you do stuff like that. You could have power back feeding a module and fry some EXPENSIVE stuff. Use diodes in the future. Much safer than just splicing and powering circuits.
