So I went with new wheels and tires and they rub...
Ram7081
HEMI 5.7
The stock size tire rubs on the rough country UCA. What options do I have besides new wheels?
Do all aftermarket UCA rub on stock wheels/tires?
275/60-20
Stock 20x9 wheel.
Thanks
rzr6-4
nebraska
Depends how bad it is. If they barely touching, a 1/4" spacer could get you buy without changing any load capacity or appearance. If you're hitting 10 degrees short of full lock then yes, you may have to go with new wheels.
Ram7081
Ram7081
HEMI 5.7
Deleted
Ram7081
Ram7081
HEMI 5.7
deleted
Stringer45
FL
IS THIS AN ISSUE WITH rc MORETHAN others in generaL? seems like a lot of rcx clearance issues.
Ram7081
Ram7081
HEMI 5.7
I ended up ordered longer studs.
Ram7081
Ram7081
HEMI 5.7
I think its because the aftermarket is using bigger ball joints. Or, some are at least. So the housing is bigger.
