[SOLVED] Help with air conditioning problem
usocazy
San Antonio, Texas
Hemi 5.7l
So my AC has been having intermittent problems. Fan/blower turns on at times on demand, other times it won’t. AC and side view mirror defroster lights come on without fail.
Pulled the AC controller, from inside the cab, off to check power to the connectors. Had power to all but the black/green wire on the fan/blower connector - no sure if that’s power out wire.
Went back later to check and had no power to any of the wires on that same connector.
Anyone know which fuse or relay to check for the AC fan/blower? Couldn’t get a good feel for that when checking my fuse box schematic.
Anything else I should check?
2004 Dodge Ram 2500, Hemi.
Thanks.
usocazy
usocazy
San Antonio, Texas
Hemi 5.7l
So I had a couple of buddies at work check out all of my fuses and relays, everything checked out.
One of my buddies did some googling and found the follow write up:
Ignition switch & AC issue:
https://sparkys-answers.com/2011/09/2003-dodge-2500-pickup-blower-not.html
In that article, the guy has some AC issues that points to a bad ignition switch.
I was very skeptical but we started with replacing the blower motor resistor - still no AC.
Next we moved on to the ignition switch - got this part at O’Reilly’s:
And here are pics of what I found once we got the old one out - right top and bottom pins are scarred:
Closer view of scarred pins:
Popped the new one in, reassembled and instant cold AC again!!!!
It also solved my enduring problem of the blower/fan always remaining on after turning off the truck if the fan was left in any “on” setting. I’ve had that problem since I’ve owned the truck (over 8 years now) but always just remembered to turn the fan off.
Hope this helps others.
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
Thanks for the update , I am sure it will help someone :)
Steedrock2
I'm having same problems Im going to change out hope it does same for me it has killed my batteries by staying on when i have forgot to turn of fan switch
