Spark plug part #
rzr6-4
nebraska
Finally replaced the bad water pump and my U-joint that was about to turn my axle into a grenade, I can finally start taking preventative steps instead of just chasing issues.
I want to do plugs next but I want to be sure to get a good set. I've seen on the forum to avoid amazon and ebay due to knockoff NGKs. I've also heard though that RAMs tend to like the cheaper copper plugs like the OEMs, and that if you try a fancy performance set it can cause issues, any thoughts there?
I was hoping someone could give me the part # they have used that worked well for them. 09 2500 5.7 Hemi (yes it's a 3rd gen).
HemiLonestar
MD
BUT....you have a 4th gen engine lol. You'll want SPLZFR5B13.
rzr6-4
rzr6-4
nebraska
2500 & 3500 got an extra year of the 3rd gen.... I wouldn't have mentioned it if I didn't know what I was saying. Its my profile pic, clearly a 3rd.
HemiLonestar
MD
rzr6-4
rzr6-4
nebraska
Yes I know smh....it's the oddball 3rd gen platform with a 4th gen engine. If you don't know that you have a 4th gen engine.....well maybe you don't know what you're saying. Regardless: https://www.rockauto.com/en/partsearch/?partnum=SPLZFR5B13
Elsewhere in the vehicle when I can't find the exact parts I usually order for an 08, so far that has worked well, haven't run into that issue yet on the motor so didn't realize the engine was a 4th. I knew the engine was a bit different than the 08s but didn't realize if was a full generation different.
Any reason why you use that part # (for the Durango) and not the OEM one?
Mopar spark plug numbers in the Parts Department
always have SP before the actual part number. SP = Spark Plug
so remove the SP & you will find the manufacture's number
SPLZFR5B13 becomes LZFR5B13,
LZFR5B13 is the number that you would look up when in Advance Auto, Autozone, Oriellys, etc.
I have found, that if the spark plugs are on the store shelf
If the plugs are in a box of 8, the part number is different than what is stamped in the spark plugs porcelain
