Special tool for transfer case drain plug in 3rd Gen 1/2 ton?
TakingChances
Redmond, Oregon
First time doing the drain/refill on my 2004 Ram 1500 transfer case. The fill and drain plugs are both recessed and take a hex key tip (I think 3/8 inch maybe)??? The drain plug is so close to the exhaust piping though that there is only a little over 1 inch of clearance, not enough room to get any of the hex sockets in there, and maybe not even a normal hex key. Is there a special tool I'm missing to do this given the limited clearance? Would definitely appreciate any guidance. It shouldn't be this hard!
Lyle Longboat
2011 Ram 1500 5.7 Sport CC
Moosonee, ON, CANADA
I used the wrench on the Allen socket. Worked easy and quick. Plus you save some bucks on a tool you won’t be using a lot
thoffmann517
