- Jan 17, 2016
- 14,068
- 24,402
- 14 Sport
- 5.7
I know is an older thread but one question for the OP, did you run the transmission up to temp before doing the initial drain of the old fluid? some say do it after setting when all fluid has ran out of transmission, others say do when warm so to remove any suspended solids with old fluid.
just received the PPE pan I ordered and am going to do this soon.
I usually start the change by draining the tranny when i park it,then let it sit overnight with the drain plug just slightly reinstalled on my PPE pan.Then pull the plug again in the morning before dropping the pan to swap out the filter.I'd do roughly the same thing with the stock pan if you can,drain as much fluid out while it's warm,then let it sit overnight and then pull the pan in the morning. Anything suspended will go out in the hot drain,and then whatevers left to drain will drip down into the pan overnight.Start the level checking procedure with a cold or at very least cooled off transmission,as by the time you get through the level checking procedure,the transmission will be getting close to the 122F max temp for the level check
