Stalling out
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
So, truck was fine, and then went to drive it and now it kinda "bounces". The rpm will jump and dip, and if I go too slow it stalls out. Recently installed the vararam and a cutout. Any connections?
truckin151
2013 sport
Did you take off the throttle body? Is the varam on there tight with the throttle or is it off the throttle body a little? Really sounds like a vaccuume leak so thats where I would check first and for most. Also check the sensor that plugs into the orange collar to make sure it is in there, turned the right way, and plugged in
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
Could it be the battery dying? It's running to the left of the half mark.
truckin151
2013 sport
Could be, but I would check the things you messed with first. Was the battery draining prior to the cutout install?
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
Cutout isn't really "installed". Just have it down there, and can open it if I want. But not hooked to battery yet.
truckin151
2013 sport
Check around the throttle body now, make sure that everything is tight, and tomorrow take it down and have them do a load test on the battery
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
Yeah. Gonna check all of that out soon. Was with a friend and he pushed up the intake and pushed in the sensor. Didn't stall after that.
truckin151
2013 sport
Probably a vaccuume leak theen if that helped
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
Back to doing it again. Going to check it out in the morning. Stalled on my way home, and was the jerkiest ride I've ever been in. Basically felt like I had no throttle. And was hitting the brakes real fast then letting go. And then doing it again soon. At any speed. Stalled when I had to stop.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Which sensor did yall push in? Im guessing the AIT sensor, make sure the fillament wasnt cracked pushing it into the housing. Only other thing off hand I can think of is the plug for the TB wasnt competly clicked in with the holder.
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
Two trouble codes.
1. Incorrect immobilized key.
2. Random misfire detected.
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
Checked the iat sensor, and it looked fine, tightened up the seal between the vararam and the throttle body, and still having a really jerky ride.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Could be the battery then. Random misfire is normaly either a cam code for lumpy cams or plugs, but inccorect imm key is weird. I see in your sig you have the Viper aftermarket system did your truck come from the factory with a system?
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
Nah. The viper security remote start is aftermarket. I'm gonna get the battery tested after work. See what they say about it.
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
It says it could be bad wires or EGR valve. How can I test these things to make sure before I go replacing stuff?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
EGV vlave is on the side of the motor, what wires are they saying are bad? Im guessing the spark plug wires. Were any of them knocked around or unclipped when under the hood moving around the Varam?
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
Yes the spark plug wires. How often do they need to be replaced? Don't believe so, but I'll check all of that out too. Just feel like the truck isn't even gonna get me home to do this. Lol.
HemiBabe
DFW
I know on my old truck, one day it just started misfiring and it was the OEM wires that just went kaput. I couldn't even make it 50 ft in my truck lol it was crazy! But I got new wires and it fixed the problem. I hope you get it figure out!
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
How hard are spark plug wires to replace? And where would I get em? Lol.
Orca
