Steering wheel with audio controls.
Azmp1
Hey folks, if I buy steering wheel that has audio controls, is it a plug and ply swap? I’m assuming the canbus wiring should Abe there already? Or no? And will it needs programming? This is my current wheel. Or, could the volume controls be added to the current wheel?
SitKneelBend
St. Louis
3.6 Pentastar
Yes
Thanks.View attachment 524957
Yes plug and play swap (compatible years) and yes controls can be added to your current wheel.
yrraljguthrie
Sulphur, Oklahoma
etorque5.7
Be very careful if you do this swap. Make sure you count any time you turn the wheel. If you move that steering mechanism and don't get it exactly the same your steering wheel will be hard to get centered. It also screws up some of the sensors in that steering column. It can get expensive to repair quickly.
SitKneelBend
St. Louis
3.6 Pentastar
Azmp1
Azmp1
There are lots of videos on YouTube for doing the swap and/or install the control kit. I'm told this tool will make taking the air bag off much easier ( https://www.amazon.com/gp/product/B073QWMHMP/ref=ox_sc_saved_image_10?smid=ATVPDKIKX0DER&psc=1 )...I'm not an anxious person, but I once described my feelings while removing the airbag as "it felt like disarming the toilet bomb in Lethal Weapon".
Haha, i know know the feeling! Done it many times when i was building my audis and bimmers in the past, as well as once on the Ram as well. And i know people that had airbags blow while doing that. Its that and the other one always was the. "widowmaker" which was the factory jack that came with the audis at one point. The name implies the result haha.
WY-Dave
Cheyenne, WY
6.7 CTD
Sorry to hijack, but will the add on work with the 5" or just the 8.4"
Azmp1
Azmp1
From what i'm reading looks like should work with either. ra2 as well
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Thanks for posting the tool. I had to remove an airbag from a Jeep recently without the tool and it was heck poking & hoping to get those clips free. I might order it just incase for next time.
SitKneelBend
St. Louis
3.6 Pentastar
Someone on here pointed it out to me too. It definitely would have made things easier...
JmGuTe
PA
Hey all sorry for reviving an old thread but I just added the audio controls to my 2013 Ram. Everything worked at first but now after putting everything back together I cannot scroll through the cluster menu. Its stuck at the MPH screen. The VR or phone buttons don't do anything. Seems like something is backwards because now the back button (left arrow) toggles the voice command. Any thoughts?
SitKneelBend
St. Louis
3.6 Pentastar
Installed backwards maybe? It's been a while since last I was in the steering wheel.
JmGuTe
PA
Yeah I thought that too but the connector only goes in one way. Just tore it apart and put in the original one and works fine, and audio buttons still work. Thinking its a junk switch which wouldn't be far from the truth since I got it off of eflay. Oh well I really only wanted the audio controls so i'm still ahead!
SitKneelBend
St. Louis
3.6 Pentastar
Well since you've seen the harness you can tell it is VERY easy to break. There was actually a recall for this where they added a retainer to the harness to keep it from breaking under normal operation. When I added my steering wheel controls I shorted the harness which resulted in the horn blaring as soon as I reconnected the battery. The recall is R36...
