Stock Air shock question
rblochli
NJ
2024 Limited
Hemi 5.7 eTorque
2016 1500 Laramie Longhorn with factory air suspension. Front left has a leak. I find two part numbers:
68232283af
4877147AH
anyone know which is correct? I think it’s 487147AH and the other may be the for the rebel?
thanks
Jeepwalker
WI
2012 Reg Cab, 4x4
1) Crawl under the truck behind it's front wheel and try to locate a sticker with the part number on the shock. If you can find it, see if you can get your phone camera close enough to get the part number. You might have to remove the wheel depending where the sticker is. This is the best way IMO in case what you actually have ...and what your truck "should" by any computer list for whatever reason don't match.
2) Type your vin into the mopar parts page and it *should* (with luck) indicate you what you need. I would still verify by eye though. https://store.mopar.com/v
rblochli
rblochli
NJ
2024 Limited
Hemi 5.7 eTorque
Thanks I’ll give that a shot
