Stuck in 4th gear
Sametboys
San antonio
Hello, first post here , I have a 2010 2500 5.7 that is stuck in fourth gear with the P0750 “Low-Reverse Solenoid”. E387FF6F-8926-4D98-B171-8D3AEA8F532E.jpegI see that the shift solenoid is the most common culprit but I found this when doing some exploring. Could this be related? Any insight would be appreciated! Thanks in advance.
mtofell
Usually, stuck in 4th gear is "limp mode" and it's the symptom, not the problem. The tranny does this to prevent further damage. That's good you got a code. Many tranny problems don't generate one.
jws123
nj
Check fluid level then un hook battery for few hours and re connect see if it shifts.
Lowrider357
