I have had te truck serviced at Dodge 4 or 5 time now (108,000 miles) and they have not changed the gear oil or mentioned the syn to be used. do I need a additive for the limited slip diff?
Thanks for the advice.
Synthetic yes. Additive, no. HDs do not have clutches in the diffs, so no additive is needed.
From the owner's manual:
"Front and Rear Axle – 2500/3500 Models:
We recommend you use SAE 75W-85 HD Ram GL-5 Synthetic Axle Lubricant. Limited slip additive is not required for Limited-Slip Rear Axles."
Also, your truck definitely falls into the "Severe Service" category. Diff fluid should be changed every 20k miles:
"2500/3500 Models:
Inspect the front and rear axle surfaces. If gear
oil leakage is suspected, check the fluid level. If using your vehicle for police, taxi, fleet, off-road
or
frequent trailer towing, change axle fluid."
(Can't copy and paste the maint sched chart, but the first "X" is in the 20k mi or 2 yrs column for diff fluid)
