Synthetic Oil
Oil of Choice
  • Castrol Syntec/Edge
    Votes: 239 8.5%
  • Royal Purple
    Votes: 328 11.7%
  • AMSOil
    Votes: 404 14.4%
  • Valvoline Synpower
    Votes: 162 5.8%
  • Mobil 1
    Votes: 1,002 35.8%
  • Other
    Votes: 665 23.8%
  • Total voters
    2,800
Mister Luck
cassis tutissima virtus
WEST COAST
5.7 V8
Can gear oil be used for its rust inhibitors for other projects like preserving metals ? Or cleaning ?
quickster2
SE Michigan
2015 Ram Laramie 2500 4 X 4
6.4L
Yep, several around these parts put there used engine oil on there wooden trailer decks.
Treated wood not what it use to be......
I use a mix of old engine oil and diesel on my hay wagon and 25' Gooseneck deck boards. The drippings work well as an undercarriage rust inhibitor at the same time. I just roll it on thick in the summer and it gets absorbed well.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
You are correct, I forgot to mention the diesel fuel mix.
Burla
2010 Hemi Reg Cab 4x4
Not to sway off the current posts, but after alot of reading on here, and asking questions I went out last month and ordered up the new base for the truck. Ordered up a half dozen RP filters, a dozen bottles Lubegard, and got 3 5liter jugs of 5W30 PUP on sale for $41.99 each ($31.04 US).
Well walking through a local CT tonight I literally turned a corner and smack dab looking at some clearance oil on a shelf. Got all 11 1q Redline 5W30 that were sitting there, $9.93 each ($7.34 US).
They have about 14 Redline 0W40 sitting there, but I quickly googled someone asking Burla about that awhile ago and got the answer I needed, left them there.
So next oil change I will do the RL. The one after can I mix the quarts I have left with the PUP? And would I bother throwing any Lubegard in that mix seeing as there will be about 3 q of RL??
Do you have hemi tic that was helped by lubeguard or you just running it for the extra protection? I generally dont see the benefit of mixing biotech with redline, now your mixing makes it less on an issue since you have most of the sump PUP. You are mixing two ester products and in theory that can "potentially" throw off the balance of the oil. Unless this helps a certain situation you are having, I would not be heading this direction.
Lubeguard is 100% safe when used with shelf oils, redline is 100% when ran by itself, lubeguard plus redline is an unknown. Small risk does not mean no risk. There is a lot of paper in this thread on benefits and risks of esters.
Buddy
Ottawa, Ontario - cool town
No just want prevention. That was the PUP Lubegard route. I just happened upon the Redline deal. I wasn't going to mix the Redline/Lubegard, but with the extra liters of RL I will have for the 2nd change I was wondering if adding them to the PUP would have enough benefit that maybe adding some Lubegard???
I will just do a RL/PUP the 2nd change out then..??
Burla
I have said it like 100 times or more, if my opinion has value, dont mix biotech and redline end of story. The only exception is if redline didnt kill some hemi lifter tick, then potential benefits out weight the risks. I dont really have anything else to say on it. Yes mixing redline and pup is 100% safe or redline with any shelf oil. Perhaps even a good idea, using 5w30 redline x a quart versus biotech 15 ounce. I can make an argument that the redline used in this manner would out perform the biotech when you consider viscosity and other aspects of both products.
It seams on this issue has it happens a good bit is that people ignore what I am saying and just use their own strategy, which is perfectly fine. But I'm not changing my thoughts on it, esters react with seals, if that goes out of balance it is an issue. Shelf oils are nuetral, they arent gonna mess with this, biotech is an ester product along with moly. It is poor mans redline a fine strategy by itself, but their is a reason why it is called poor mans reldine and not rich mans redline, it is not as effective.
Buddy
So maybe a good route while I have the RL is mix a quart with the PUP and shelf the Lubegard until all the RL is used up? Then breakout the LG for the PUP changes way down the road.
Murphy Slaw
Southern Illinois
2016 Bighorn 4X4 Crew
Hey, long time no post.
How you guys been? All is well here, my Hemi is about 91,000 tick free miles. Been running Amsoil SS 5-20 for a long time.
I think I'm going to switch to 5-30, getting up in miles and such. What do you think?
Oh yea, I wrote a new song about my Granddaddy's Pocket Knife.
Burla
Murphhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh!
Man it's been too long you ol toad, look like you been eating well :)
Thanks for that song treat of a song right there. Operate on the dog, lol.... You made my day, ode to the pocket knife, love it.
Burla
Campbells-Grilled-Cheese-And-Tomato-Soup-FT-BLOG0306-2b2a054d47cf4a41b318c64ab35bd0d5.jpg
Well, at first glance it's a no? I mean nothing better then grilled cheese and mato soup, top 5 dish for me, maybe top ten, but common now you cant put that in a can? I must admit if I see it I will try it, but I am not having high hopes. I seriously doubt this tops my 2 favorite soups minestrone or chicken and dumplings. What is your favorite soup??
Murphy Slaw
Southern Illinois
Thanks, Burla.
You da man.
So, ya think I should move to 5-30 after all those miles?
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4L HEMI
Well, finally bit the bullet and changed the two UTV final drive gearbox oils. Had to remove brush guards just to get at them, despite holes in them supposedly for service access. Holes aren't big enough or aligned right.
What a PITA for just 20 ounces of gear lube change. 3 hours worth.
I suppose Red Line MT-85 manual gear oil is made in such small batches compared to ATF it costs more.
I confirmed in my Owner Manual it states only GL-4 SAE 89W
No mention of GL-5 EP gear oil as alternate, so I didn't know until you guys chimed in. Oh well it's done. This is a chores machine, don't ride thru watee.
Burla
Thanks, Burla.
You da man.
I will come out of retirement for one last recommendation, in the future if someone needs some help pm me :)
Yes, you should move to 5w30 for the rest of your trucks days. Especially amsoil SS which is a very low viscosity for a 30 weight, it is even thinner then their 0w30, at 10.3 it has a thin starting 30 weight visc. Hemi 395 uses their 0w40 SS which has been proven against hemi tic a real option now. However, that is very thick and as long as you are tick free, stay put with 5w30 and pair that will their ea filter, you are using their larger filter as well??
Travis8352
Houghton michigan
I prefer my wifes homemade French Onion soup over canned soups :Big Laugh:
