the codes
- Jan 8, 2012
- 4,210
- 160
- Location
- Houston, Tx
- 1998
- Magnum 5.2
BE VERY CAREFUL with the thermostat housing bolts...they like to break off in the intake...and dont forget to burp the cooling system really good when you're done!
Sure...it's really easy if ya got a set of ramps or somewhere where you can park the nose of the truck up on an incline. the idea is to get the radiator sitting higher than the engine and heater core.
Get the truck up on an incline, let it cool down...open the radiator cap and pull it off. Turn the truck on and let the tstat cycle open and closed a couple times...any air in the system will find its way out the water neck on the radiator...you might have to add a little more coolant after it burps as the level might go down.
X2...the PCM is just gonna adjust your air/fuel ratio and make it could start to burn rich...enough of burning rich = valve problems, catalytic converter problems...etc over time. That's only if you're running too cool for the engine to go into open loop.
