Bandit-8
I run a search on here looking for this info but came up with nothing. So here is my problem I need some help with.
I bought a 1998 Dodge Ram with a bad tranny. The engine a 8.0 L - V 10 Ran perfect when I bought the truck. I started it several times and could move it around in reverse only as all forward gears were not working.
Any how I took it to a garage and had them pull the transmission so I could work on it. It took me about 3 weeks to DIY the rebuild on the transmission.
I delivered it back to the garage and they re- installed it.
But now the engine will not run. It will not even try to fire up. Being that the truck has 168K on the clock I went ahead and had them drop the tank and I installed a new Specter fuel pump module which comes with everything including a new float and sender. But the truck still does not run, in fact it won`t even try to fire up.
I made a couple phone calls and was told by one mechanic that there was a crankshaft positioning sensor some where on the back of the block near the bell housing and that the mechanic that R & R`ed the tranny probably bumped the sensor and that is whas keeping it from firing up.
What I need to know is where is the crankshaft positioning sensor located on the 8.0 L -V 10 engines and how will I recgonize it. Also with the miles on the vehicle should I just buy a new sensor for the truck?
Any help will be appreciated.
Thank You
Bandit 8
Thank You
Bandit 8
