RHorseUSMC
So I popped the hood on my 2013 Ram 1500 just so I could make sure it was 5w-20 oil that I needed to get and when I did I noticed the big plastic engine cover was tilted a little to the side and was loose. Last weekend I had pulled it off along with the S&B intake tube and did a good cleaning on all the plastic. I guess I didn't get the cover installed properly. Anyway, I fought with it trying to get it secured but it's kinda of a PITA without taking the tube off. So I unplugged the Air Temp Sensor, removed it and secured everything back properly. I start the truck up and check engine is on. Thinking it was the intake temperature sensor (as it has been many times before) I checked that with no luck. So after scanning it I find out it's a " P0456 - Evaporative Emissions System - Small leak detected.".
This is usually a gas cap issue but I've checked that with no luck. I've even tried to clear the code with no luck. I've checked to make sure o didn't knock any hoses off when I was messing with the engine cover and everything is tight. There not to much under that cover that I can see pertains to the Evap system but maybe I'm missing something? Any ideas? I had to have hit something when trying to get the cover back on. I hate to take it to the dealer. 3 year warranty was up 3 weeks ago.
