Tick after header installed
iwon
Okay so I just got my truck back from getting a set of jba shortys installed. And now it makes a ticking sound when I drive and it speeds up when I speed up. Is that normal?
DILLIGAF
Canada
Yup, Engines become way more noisy once headers are on :)
Burla
2010 Hemi Reg Cab 4x4
webcam the sound.
iwon
iwon
I'll post a video tomorrow hopefully
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
What gaskets did you use, read some of them are cheap and can blow out right away.
might double check to make sure none are blown.
gmbohuntr
Yeah, sounds like a possible exhaust leak. But headers do make a bit noise.
Sent from my SAMSUNG-SM-G920AZ using Tapatalk
Gamester
Yea, when I had my ARH long tubes installed a while back, there was a noticeable tick as well that is just loud enough that we thought there was a leak, however we went over them up and down and there were no leaks to be found. Headers are just plain loud in every sense.
Just curious, why did you not go with long tubes instead as they add much more power than shorties?
iwon
iwon
They are ramflex header gaskets
iwon
iwon
Yeah that's what I was thinking but you only really hear it around 2500 rpms or higher
iwon
iwon
That almost sounds like what i have going on. Did they get faster as the rpms went up?
Mainly the price. But I basically just got these to replace my warped manifold.
iwon
iwon
webcam the sound.
I couldn't get the ticking sound on video... the engine was too loud.
stoviAZ
Yoire hearing the valve train through the thinner headers.. Mine does it too with kooks LT. Drove me nuts for a bit.
Sent from my LG-H910 using Tapatalk
HammerHead
USMC 0313
Georgia/Florida
2019 4Runner
I just put my KOOKS on last week and where the header meets the Mid pipe all they gave we was clamps, and they leak. You have any leaks?
stoviAZ
I had my headers welded to catkess mids ... No leaks
trikeffex
Hammond,La
2013 sport ram
Yep as stated you are hearing Valvetrain noise through the Primaries. That's the reason I've never installed Longtubes on my 17' and don't know if I ever will. I have to deal with it on my Singlecab GM till we get the Turbo installed, Then I won't have to hear it anymore. As stated also, Wrapping the headers can help with the noise.
Charles
wstacy3
Header wrap will speed up corrosion
