ticking noise after cleaning injectors... should I worry?
KansasRam1997
Lawrence, KS
5.9L 360 Magnum
Took out all my injectors and cleaned them individually with carb & choke cleaner... after putting them back in 1) i notice a little more power 2) also the truck shakes more at stoplights while idling 3) there's a noticeable 'tick' sound coming from one of the injectors it seems like. Should I be looking out for anything in particular? thanks
dapepper9
Iowa/Nebraska Border
5.9L V8
How did you clean them? I'm betting you have injector leakage now and it's causing a misfire
K
KansasRam1997
Lawrence, KS
5.9L 360 Magnum
I found the solution, the engine was throwin misfire codes real bad... went under the hood and noticed one of my spark plug wires were off my distributor! I must of popped one off on accident when I replaced my Idle Air Control valve... I feel dumb lol
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
Don't feel too bad. We all make mistakes this one was an easy, easy fix.
Gr8bawana
6.7 CTD
Good to hear it was something really simple.
amocoharley
7 cylinders always feels more powerful than 8.
