Tire Conversion Chart.
Discussion in 'Exterior' started by powerhour, Jul 16, 2010.
Sponsored By: BAK Factory Outlet
  1. powerhour
    powerhour Senior Member
    28
    259
    Jul 9, 2010
    Campbell River, BC
    Ram Year:
    Engine:
    3.6
    i hope this helps!
    225/85R 14 = 29 X 9.00 X 14
    215/75R 15 = 28 X 8.50 X 15
    215/85R 15 = 29 X 8.50 X 15
    225/75R 15 = 28 X 9 X 15
    235/75R 15 = 29 X 9 X 15
    325/60R 15 = 31 X 12.50 X 15
    Q78-15 = 35.50 X 11.00 X 15
    215/70R 16 = 28 X 8.50 X 16
    225/70R 16 = 28.50 X 9 X 16
    225/75R 16 = 30 X 9 X 16
    235/70R 16 = 29 X 9.50 X 16
    235/85R 16 = 32 X 9.50 X 16
    245/70R 16 = 30 X 10 X 16
    245/75R 16 = 31 X 10 X 16
    255/70R 16 = 30 X 10.50 X 16
    255/85R 16 = 33 X 10.50 X 16
    265/70R 16 = 31 X 10.50 X 16
    265/75R 16 = 32 X 10.50 X 16
    265/80R 16 = 32.50 X 10.00 X 16
    275/70R 16 = 31.50 X 11 X 16
    285/75R 16 = 33 X 11.50 X 16
    295/75R 16 = 33.50 X 12 X 16
    305/70R 16 = 33 X 12.50 X 16
    305/85R 16 = 36 X 11.50 X 16
    315/75R 16 = 35 X 12.50 X 16
    325/70R 16 = 34 X 13 X 16
    325/80R 16 = 37 X 13 X 16
    365/65R 16 = 35 X 14.50 X 16
    Q78-16 = 35.50 X 11.00 X 16
    265/70R 17 = 32 X 11.50 X 17
    275/70R 17 = 32.50 X 11.00 X 17
    285/70R 17 = 33 X 11.50 X 17
    295/70R 17 = 33 X 12.0 X 17
    305/70R 17 = 34 X 12.00 X 17
    315/70R 17 = 34.50 X 12 X 17
    255/55R 18 = 29 X 10.50 X 18
    285/60R 18 = 32 X 11 X 18
    285/65R 18 = 33 X 11.50 X 18
    325/60R 18 = 33 X 13 X 18
    325/65R 18 = 35 X 13 X 18
    355/65R 18 = 37 X 14 X 18
    305/50R 20 = 32 X 12.50 X 20
    305/55R 20 = 33 X 12.50 X 20
    325/60R 20 = 35 X 13.00 X 20
    355/60R20 = 36.50 X 14.00 X 20
    325/50R22 = 35 X 13.00 X 22
  2. glass3222
    glass3222 Senior Member
    37
    2,340
    Jul 2, 2010
    Central PA
    Ram Year:
    2005
    Engine:
    Good info.
    Or if you want to convert it yourself:
    1. take the first number (the width in millimeters) and divide by 25.4, this give you the width in inches
    2. multiply be the second number (aspect ratio) divide by 100 (percentage), this gives you the sidewall height
    3. multiply by 2, the add the 3rd number (wheel diameter)
    Example: 275/60 R20 (factory 20" Ram tires)
    1. 275/25.4= 10.82677 inches
    2. 10.82677*60/100 or 10.82677/.6 = 6.496 inches
    3. 6.496*2 = 12.992 + 20 = 32.992 = 33" tire height.
  3. Deviate
    Deviate Senior Member
    710
    31
    Jul 2, 2010
    St. Augustine, FL
    Ram Year:
    2005 4x2
    Engine:
    4.7
    That chart and formula will get you in the ballpark, but depending on the manufacturer the actual tire height will vary because of tread pattern or what have you. Case in point:
    265-70-17 AT tires:
    Formula Height: 31.61
    Nitto Terra Grappler actual height: 31.57
    BFG AT: 31.8
    Dick Cepek Radial F-C II: 31.7
    Not that a 10th of an inch makes that much real world difference, but just pointing that out.
  4. ramhunter9
    ramhunter9 Supporting Member
    24,508
    884
    Jun 25, 2010
    Ram Year:
    Engine:
    P-Star Jeep Wrangler
    good info fellas .. stickie time
  5. rocket
    rocket Supporting Member
    14,815
    2,345
    Jun 26, 2010
    connecticut
    Ram Year:
    2006 Nightrunner
    Engine:
    HEMI 5.7
    HHHmmmm not posted above . whats up with that op??:birgits_tiredcoffee
  6. glass3222
    37
    2,340
    Jul 2, 2010
    Central PA
    Ram Year:
    2005
    Engine:
    ????What do you mean?????
  7. ramhunter9
    24,508
    884
    Jun 25, 2010
    Ram Year:
    Engine:
  8. Bigtman07
    Bigtman07 Registered User
    9,306
    207
    Jun 28, 2010
    Eaton, Ohio
    Ram Year:
    1998/2000
    Engine:
    Magnum 5.9/Cummins 5.9
    OMG You guys are saints lol. Awesome info.
  9. headhunter123
    headhunter123 Member
    38
    99
    16
    Feb 21, 2015
    Ram Year:
    1997
    Engine:
    5.9 V8
Share This Page
