Tire fit question
Jaxyaks
I have a 2014 2500 4x4 with the stock 285/60/20's. Will a 33 12.50 20 tire fit on this rim as well as fit on the truck with no issues. Truck is stock
2011 Ram 1500
Yeah, you can run up to 35's with out needing to level
Skrap
Orange County, CA
2015 Laramie MegaCab 4x4
For clarity, 35x12.50-18 will not rub on a stock 2500? Or, would it have to be a bit narrower tire. Sure wish I could see some members pics with this setup.
Eric SA
San Antonio
Cummins 6.7
I have 13 and it has a lvl kit. I have 35x1250x20 on a 10" rim and I had to "pull back" the plastic liner in the wheelwell
hemi1282
Arkansas
2016 Ram Tradesman
295/60/20 toyo mts stock barely rubs control arms at full lock
Wandell
Cummins 6.7
Yeah, it's easy to fit a 35x12.50 on these trucks at stock, or leveled ride height. Unless you try to use a 12 or 14 inch wide wheel that is.
Orca
