DatacomGuy
Towing this afternoon with the new tires..
Should I be airing up to the recommended 80lbs?
And all four tires right?
With all due respect, this is something that needs to be validated or debunked.
A metal rim isn't going to fail at pressures that a tire can hold. The bead and valve may be another story.
Oh, gotchaYeah I was just trying to point out where the 80 psi numbers might be coming from.
I don't think that's where 80 came from. It's more likely it's from all the comments about aftermarket E load rated tires. Most have max 80PSI. A matter of fact, just two different threads I've read today from smurfs_of_war make mention of the 80 psi debate.
Most of the E load rated tires in 275/65R20 for example have a max PSI of 80.
I think it has to do with the aluminum rims. They would likely fracture before they bent, wouldn't they? I don't know for certain... that's why I asked about the pressure.
