Tire size w/ leveling kit??
GlOcKnRaM
Mebane, NC
5.7L V8 Hemi
Ok after a ton of searching here I am! Ive googled till my eyes exploded and creaped on everyones pages. To no avail I still have questions! I am installing a 2.5 HBS leveling kit on my ‘12 and want to run a bigger tire. I kind of want to just keep my stock "20 for now. But can I run 35x12.50? Is anyone doing this without issues? Or should I just run a 33x12.50?? Any help would be greatly appreciate...
1500ram12
5.9L Cummins
You can but you'll need wheel spacers up front. I think a lot of people are running 295/50/20
Sent from DROID RAZR MAXX using Tapatalk
GlOcKnRaM
GlOcKnRaM
Mebane, NC
5.7L V8 Hemi
Thats what I was thinking, in the trail grapplers..but the 33x12.50 nitto mud grapplers have my attention and the 275/65/20 Duratracs...just dont know what would be the best fit.
4x4Hemi
Edmonton, Alberta
I run 35x12.5 with 2.5 level, but i have new wheels, you could run 35's with just a spacer
pd298
SE Oklahoma
i am going to get 295-65-20's when i get tires. they are like a 35x11 or so.
quietpeen
2021 TRX
Hellcat
moved this to exterior since it is about wheels.
as said you would need wheels spacers to run those on stock wheels
GlOcKnRaM
GlOcKnRaM
Mebane, NC
5.7L V8 Hemi
Ok so im getting some spacers from a member on here, just the front two and I think they are a 1/4 inch..would that be enough to clear 35's?
quietpeen
2021 TRX
Hellcat
its not the height that is the issue, its the width. Yes i believe you will be good with the 1/4" spacers.
the 2.5" level kit is what will allow you to fit 35's
GlOcKnRaM
GlOcKnRaM
Mebane, NC
5.7L V8 Hemi
Ok thanks for that, cause I assume the spacers is just a set for the fronts. I just want 35's so maybe I should get new wheels for a more narrow wheel?? A lift is in the near future so I figured Id go ahead and get 35's.
quietpeen
2021 TRX
Hellcat
if you get new wheels you can easily run a 12.5" wide tire because you can get a wheel with less backspacing which moves the tire away from the upper control arm
GlOcKnRaM
GlOcKnRaM
Mebane, NC
5.7L V8 Hemi
Oh ok..well kind of a new guy question, but how will I know if they have less backspacing? Is that the offset?
quietpeen
2021 TRX
Hellcat
no problem ask as many questions as you need. Offset and backspacing are two different measurements, but directly related....offset is a measurement from the center line of the wheel to the mounting face. Backspacing is a measurement from the back edge of the wheel to the mounting face. A positive offset moves the mounting face toward the front of the wheel, and a negative offset moves the mounting face toward the back off the wheel. More positve offset = more backspacing, and the more negative offset = less backspacing.
Personally i think a ideal wheel would be 20x9 with 0 offset. Some lifts require a minimum amount of backspacing so since you plan to lift in the future i would see what the lift manufacture recommends for backspacing before you buy wheels.
GlOcKnRaM
GlOcKnRaM
Mebane, NC
5.7L V8 Hemi
I just learned something new, thanks never knew all that. Ok good because I am looking at 20x9 MB TKO wheels from discount tire w/ a 35x12.50 Nitto Trail Grappler. But I thought if I got spacers I could just run my stockies for now w/ a "35 tire. Unless I could sell my stock wheels and tires to someone.
quietpeen
2021 TRX
Hellcat
yea, with the 1/4" spacers you will most likely be good. How long till you buy new wheels? I would consider the cost to have those 35's mounted and balanced twice.
GlOcKnRaM
GlOcKnRaM
Mebane, NC
5.7L V8 Hemi
Thats what im tossing back and forth...and leaning towards just doing it all at once...or just keeping it simple/ less expensive and just doing some 275/65 Duratracs. To many choices haha
BigSexyBlue05
2012 dodge ram quad express
What is your set up? Lift and rims!
BigSexyBlue05
I just have a hell bent steel 2" level kit, 20x10 rockstars with 4.5" backspacing and 33x12.5x20 toyo mt's
Love the look. I want to do the hbs 2inch. Was also thinking 1.25 body lift. But I'm not sure if it's over kill.
quietpeen
2021 TRX
Hellcat
Thanks, no way is a 1.25" body lift overkill. Look at 0212353's truck he has same level along with said body lift and 34.5" tires
GlOcKnRaM
GlOcKnRaM
Mebane, NC
5.7L V8 Hemi
Im also thinking about the body lift, I dont think its overkill!
Lowrider357
