tires
rcajper
Powell Wyoming
cummins
what is the largest tire i can put on a stock height 1999 4x4 , it hasthe cummins and i do not want to cut. does anyone know. i am going to put a small lift on it . but not in the near future
Yeret
The Village Drunk
Under the hood fixing/breaking something.
5.9 Magnum
I had 265 75 16 when I first got the truck. They would rub about 80-90% of the steering input. I've got 255 75 16 now and no problemo.
I'm thinking 285's would rub at or less than 75% of steering input. My sister used to drive a Monte Carlo with wider than stock tires that would rub at about that point and that car was a real PITA to turn into a parking spot.
I have no idea how much effect that a lift would have.
Max78
AZ
Magnum 5.9
Im running 265/75/16 Kumho AT51 with zero rubbing offroad.
My moms Cummings is running 285/75/16 Kumho AT51 and has zero rubbing offroad as well.
dapepper9
Iowa/Nebraska Border
5.9L V8
I was running 265/75/16s zero rub and nowhere close to rubbing. With the new wheels with a -12mm offset and less backspace I'm currently running 285/70/17 and without the wheel well liners (mud bog incident) im fairly confident i could've stuffed 315s if i wanted, with very little to zero rub. I have since leveled though and i could definitely run 35s
Max78
AZ
Magnum 5.9
My brother in law had 315/75/16 BFG AT on his 01 4x4 Cummins, it only rubbed in really bad areas where he was turning while articulating pretty good. Still that truck went all over AZ in some really tight spots and it never rubbed enough to worry. He did have wheels that pushed the tires a little further out than the stock location.
Both my truck and my moms truck are of stock wheels.
As for rubbing at full lock, check and see if your stops are still there.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
285/75 with AR wheels and I only rub at full lock. Both the CA and splash shield
cdstl
285.70R17 on Gen 3 8" wheels with zero rub. I do have a 2" level on the front.
Orca
