tprice9427
- Jun 27, 2013
- 177
- 24
- Location
- Chesapeake, VA
- 2016
- Hemi 5.7
Very nice!
Which one is that?
Tprice: Nice looking cover.
Dmclone: I can buy a new Tonneau Pro every three years for nine years and still pay less than the bak-flip.
Got the oem mopar... it is hard tri fold and can be open from the front and locks on both ends... Thanks!
Sent from my iPad using Tapatalk 2
I've been researching this quite a bit over the last several weeks. I'd say if you have the extra money laying around, go for a Bakflip.
Otherwise the Tonno Pro looks like a good bargain. That's the route I'll probably be going.
I use to buy used vehicles and spend a ton on mods. This time I decided to take that mod money and put it towards getting a new truck instead. So needless to say, any mods I do get have to be relatively inexpensive.
I'd buy an Undercover Flex over a Bakflip because:
1. It stands vertically instead of leaning against the truck.
2. It costs less.
3. It's made of FRP instead of aluminum (G2 and HD are aluminum).
I'll be going Tonno Pro myself. Can't beat the price. Tri-fold most likely.
2. It costs less.
It's probably made by either Advance Cover or Fold-A-Cover.
This might help with your decision. By the way, I do not work for or have a financial interest in either Bak or Undercover.
Here are pictures of the hinge area of a Bakflip and Flex, you can decide which one looks nicer.
Bakflip
Flex
The thickness of the horizontal seals of the Bakflip and Flex are exactly the same thickness (I measured with caliper). However, the Flex has two vertical pieces of rubber between the panels which the Bakflip does not have.
Bakflip
Flex
Maybe you should show pics of the nicer Bakflips. My F1 hinges look nicer than that and more heavy duty.
