Gamester
- Jun 23, 2016
- 466
- 111
- 2016
- 5.7L Hemi
Hey guys,
So, for a years now I have been running my Procharger with no real issues to speak of. However, a few months ago, all the sudden the engine torque management has seemed to have declared war on my boost and has even been throwing bad enough codes about the engine torque management to put it into limp mode, which it has never ever done before.
Normally, I will have 9-10lb of boost through every gear with no issues and now I'm lucky if I see 3-4lb. At first, my speed shop guy and I thought that there may be some belt slippage issues again, but we have now eliminated that issue via mechanical fan delete and found a suitable size green belt to fix the belt stretching we were having and that helped some, since when it started there were times with no boost at all, but that did not resolve the issue entirely.
My speed shop uses HP tuner to manage my setup and transmission tuning as well and we have done quite a bit of data logging and testing and are having troubles pinpointing the root cause of this issue. I have read some mentioning of the possibility of disabling the engine torque management itself over at the HP tuner forums...
https://forum.hptuners.com/showthread.php?63996-8-Speed-Torque-management
...,but not sure we should try that or not. Has anyone else around here with boosted 8-speed Rams been through anything like this?
Thanks
Thanks
