I have a 2013 1500 and this past fall bought a Jayco 27' Travel Trailer as they were on clearance with the winter months approaching. I believe dry weight is around 6000lb, with a tongue weight of around 550lb.
Regardless, when I towed it home... my rear end was sagging pretty good...
I have since put 5100's set to 2.1" on my front to level my truck out some. Its safe to assume the sag will be even more noticeable now.
I'm planning on putting airlift 1000's on it, the only concern I have now is if the trailer is going to be to nose high? The hitch I have has a 2" drop to it. Should I invest in a hitch that is adjustable?
Thanks.
Thanks.
