Towing capacity chart for 2004 Ram 2500?
bobham
Kaukauna WI
I'm new here, I'm thinking of buying a 2004 Dodge 2500 4wd truck. I'm trying to find the literature that tells me how much it can tow...officially.
B
bobham
Kaukauna WI
2004 Dodge 2500 with cummins diesel with regular bed, crew cab. Looking for weights and towing capacities.
Smokeybear01
US-NW Coast
Cummins 5.9
Hey Bob, Everyone must be outta town so I'll ask the easy question first--did you check the sticker on the door?
392DevilDog
Glasgow, Pennsylvania
392 Hemi
Sorry. Forgot all about this.
The GCWR is 23000 for the Cummins. 17000 for the Hemi. (99 percent sure)
So you need the base weight of your truck and then subtract that, passengers/cargo/hitch from the 23000 GCWR and you have your trailer rating. You also need to be sure Pin/tongue weight does not put you over rear GAWR
HemiLonestar
MD
In case anyone wants to look up theirs: http://www.rambodybuilder.com
Caveat: it only goes back to 2004 and the tow charts to 2005, however I would be confident in saying the info is good back to 2003.
B
bobham
Kaukauna WI
Yes, all I see there is the Axle limitations (5200lbs front and 6000lbs back). I also see GVWR of 9,000lbs. I'm thinking that means I can put; a maximum of 5200 lbs on the front axle, or a maximum of 6000 lbs on the back axle. The total of course can't be over 9,000 lbs. However, what I am looking for is the amount of weight it can tow with and without weight distribution? And the amount of tongue weight that can be applied to the truck with and without weight distribution. I'v found info for modern trucks online, but nothing for the older trucks. Does this info not exist?
B
bobham
Kaukauna WI
I searched the site you linked and couldn't find that information. do you know which tabs you clicked on to find it? Thanks in advance.
