Tpms help
Scope432
Okay, a while back I had my tpms light come on with a message that stated to service tpms system, then my abs, traction control and 4 wheel drive lights came on with a message stating to service. My 4 wheel drive system. I narrowed the problem down to one of my wheel speed sensors and replaced it, this caused my abs, traction control and 4 wheel drive lights to go out and the message for the 4 wheel drive system to stop. However my tpms light is still on. I had a tire shop check all the sensors in my tires and they are all good. Anyone know what would cause the tpms light to remain on? I checked the air pressure in my tires and they are all good,
ColdCase
When you first turn the key and after the bulb check, does the TPMS indicator flash for 10-15 seconds, or more like 75 seconds before going solid? The shorter flash means low tire pressure, a longer flash means a fault condition. Fault conditions are things like bad sensor, antenna wires, module, etc. Someone with a scanner that can read TPMS codes should be able to tell you what is up..
RamCares
n/a
n/a
Hi Scope432,
If you decide to visit your local dealership for further diagnosis I'd be happy to offer assistance if needed. Just PM our page with your VIN and let me know!
Andrea
Ram Social Care Specialist
JustinRam1500
