Trailer lights
NCAC
Akron
Cummins
I bought a 2015 2500 Laramie with a Cummins. Using the trailer 7 pin plug the right turn signal and right brake light won't work. I checked power at the 7 pin and no power. I checked the fuse I believe it was 81 and it was good but no power to the fuse block where the mini fuse plugs in. Does anyone have a wiring diagram? Thanks
Tulecreeper
Sthrn AZ
The fuse is good, but there is no power to the hole it plugs into? If so, you have a power problem coming into your fuse box, not at the back where the 7-pin is.
turkeybird56
Central Texas
Gonna have to look under the TIPM where the fuse is for the Trailer Brake/Turn Signal connection. Make sure U R checking the proper fuse, on MY 19 1500, it takes a 20 amp blue cartridge fuse. If still no power to the correct fuse, than U have IMHO a connection problem under the TIPM at that fuse location.
Administrator
There is actually separate fuses for each of the pins that provide power for the 7-pin. You need to check power at the fuse with that lighting circuit on.
The fuse listing and wiring is for a 1500 but I think works for the HD trucks also
F53 ATR 20 amp Left Trailer lights
F81 ATR 20 amp Right Trailer lights
F29 FMM 20 amp Trailer Park lights
F28 FMM 20 amp Trailer Back up lights
F30 FMM 30 amp Direct from battery
F11 J Case 30 amp Brake Lever
F87 ATR 10 amp ITBM module
  • TRAILER-TOW-SYSTEM.pdf
rzr6-4
nebraska
Mine did the same thing, I just ran a jumper wire from the blinker on the truck to the 7 pin.
2003F350
6.7 CTD
That's actually dangerous, as it can back-feed without a diode and cause undesired functionality.
In OP's case, it also likely will only solve the blinker issue, NOT the brake light issue.
It needs to be fixed correctly for safety.
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Using AlfaOBD, check to make sure the right are activated.
Under "Car Configuration" then
Under "CBC Config I/O":
Connector E Pin 24: Trailer Tail Lamp Relay Control Output Present: Yes
Connector F Pin 36: Trailer Turn Stop Relay Control Left Output Present: Yes
Connector E Pin 22: Trailer Turn Stop Relay Control Right Output Present: Yes
Problem may also be in the TIPM itself
