Tranny is startin to slip
Shiloh 24
Kansas
5.9L gas
Well almost to the dreaded 100k mark and I've noticed that my tranny likes to slip a bit on occasion. What should be my first course of action? I was thinkin maybe a shift kit would make the shifts firmer and reduce slippage but I don't know that much about em. I'm not looking forward to replacing it if that's what it comes too.....
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Shift kit would hold the pressure higher but would prob just be a band-aid to get ya by. Have your dropped the pan to see if there is any excessive build up?
ramthis9501
Oklahoma
5.2 V8
When was the last time you changed the trans. fluid? That usually helps alot, plus a new filter would also probaly do the trick. Did in mine
What trans is in your truck? Do you have the 46re (I think that is the right name, same one that came in 2nd gen Ram's)?
ramthis9501
Oklahoma
5.2 V8
I think that's what I got, and like I said, a simple transmission fluid and filter change did the trick for mine
Shiloh 24
Shiloh 24
Kansas
5.9L gas
It's the 46re, I haven't dipped (dropped, ****** autocorrect) the pan or ne thing yet since it just kinda started. I checked the fluid when I changed my oil the other day and it looked fine, not burnt or dirty lookin at all.
ramthis9501
Oklahoma
5.2 V8
Mine didn't either, but we did it anyway and it helped alot
Shiloh 24
Shiloh 24
Kansas
5.9L gas
Well I guess I'll price a filter and flush with my boss, maybe he'll let me do it after work in the next week or so.
ramthis9501
Oklahoma
5.2 V8
I got the fluid for 5 bucks a quart plus the filter. Think it was like $35 total
Shiloh 24
Shiloh 24
Kansas
5.9L gas
That ain't bad at all, you just did the filter though right? We got a machine at a shop that plugs into the tranny cooler lines and flushes the entire system and puts in fresh fluid.
ramthis9501
Oklahoma
5.2 V8
Yeah we don't have all that fancy machinery lol but sounds like that would probaly help to
Shiloh 24
Shiloh 24
Kansas
5.9L gas
Yea the only reason I mention it is because that would jump the cost a bit, seeing as all the fluid would be replaced instead of just in the pan.
ramthis9501
Oklahoma
5.2 V8
Yeah but that wouldn't be much would it? The lines don't hold that much fluid when the truck is off right?
Shiloh 24
Shiloh 24
Kansas
5.9L gas
I was under the impression that the whole system held like 11 quarts but I could be wrong
ramthis9501
Oklahoma
5.2 V8
Wow! Mine only holds about 6. I know you got the 5.9, but that shouldn't be much difference if we got pretty much the same transmission
adamwilkes14
I could get you the fluid for just shipping...but you need it sooner than that I suppose...plus, shipping might be pricy on a 25 pound case of ATF...
(I work for an oil company)
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Service fill 5.2L according to the manual. Overhual, 14-16L.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Has the trans ever been flushed? I have heard from 5 trans shops saying either ya have to flush every 30k or never touch it with a flush machine.
