Trupiano
Registered User
- Jun 27, 2010
- 10,981
- 726
- 2010 Ram 2500 6.7L CTD Crew Cab
- 6.7L CTD
Damn 16 quarts? Plus another 3 if you get the deep pan huh? Wow that's alot of fluid!
yeah i think imma go ahead and get the deep pan with it just to keep it a little cooler and upgrade the trans cooler to a bigger efan unit. that price doesnt include the labor. what do you guys think about using that raptor blood tranny fluid? its on the same page as the link closer to the bottom.
Take a look at post #52...
Edit: Two problems I have with the deep aluminum pans. 1. If you are lowered you lose ground clearance. 2. If you hit an aluminum pan or a differential cover for that matter it will likely be broken were a steel one will just get bent up.
05 2500 HD trans cooler p/n 52029089ab
3rd problem: Nobody makes a filter extension so all deep pans are useless without one.
just food for thought....if the Raptor Blood runs so much cooler than reg ATF..it would kind of eliminate the need to run a deeper pan, would it not, especially with a better trans oil cooler?
