Hemi395
- Mar 18, 2013
- 9,001
- 15,713
- Location
- Cape Cod MA
- 2013
- 5.7 Hemi
eBay?
Maybe PM Mpgrimm2 and see if he has any ideas...
Count me in!Hey guys. So I'm Thinking I'm Going to test this for a month. After that if there are no hiccups I'll build these harness but, id like around 10 people who'd be on the list as I need to order plugs and resistors and diodes and switches. It'll Keep the cost down with more on the boat. There's goda be more who would want this.
Northern Alberta. Peace River area to be exact.
What would you do with 2 low though?!?
Oh nice I like it down there! I don't have Facebook Though. As you said too many idiots, I call them Google scholars spouting about what they don't know or have experienced. Lol.I'm down here in Airdrie,lol. Post this up on Badlands Rams and Berta Rams,you might get a few bites on there to.But be forewarned you'll get the genius's on Berta Rams,as some of those guys rate lower then idiots,but there's also a few guys who might be interested at the same time.
The bypass kit would be easy enough to build almost the exact same concept but the switch just open circuits. Well on the 44 not sure exactly how the 45 works.Using the low range of the transfer case would help in manuvering a heavy trailer(backing in a tight location, up a hill, etc). Keeping the front wheels from engaging will keep the driveline from binding while steering.
I made the suggestion about this set up as it plugs inside the cab.
I've thought about adding one of these kits to my truck, but I don't need the clutch bypass as I have the BW 44-45
For what I understand, the 44 & 45 is all the same wiring but the DTC controls the axle shift motor differently. Sounds like the clutch wire that your working on is also there but only acts as a shift assist.The bypass kit would be easy enough to build almost the exact same concept but the switch just open circuits. Well on the 44 not sure exactly how the 45 works.
I'm waiting for my dongle to come in so I can access that stuff wish my max me would let me fool around with those parameters. Does the price seem fair? There is definately a difference in 4wheel drive though.Ill take one, I dont need the 2WD Low, though.
Do you have an OBDMX and the AlfaOBD app? Id be curious if you can monitor xfer case temperature.
Hey guys so this is the first video of The truck in 4 high. As you can see the jerkyness of it connecting and disconnecting. Both rears are spinning and being an open front diff only the one front wheel spins.
This is simply BADASSHere is the video of the switch locked in 4 high
