- Jan 17, 2016
- 14,076
- 24,432
- 14 Sport
- 5.7
They come filled,even if it came empty,the fill procedure wouldn't be any differant,as the truck has to be running when you do the final check,throw in the fact you have to let it shift into 2nd gear with the tires in the air and spinning ,so that it fills all the clutch circuits,pretty well rules out that idea. Personally i think the directions they gave you,are a generic fill procedure,as you didn't specify the transmission runs downhill in the trucks,and expecting an office flunky in Germany to know that fact is stretching things in my opinion. Like i said,take it out and run it up through several gears with your foot buried through the floor and see how it shifts,if it shifts fine,then you probably have enough fluid in it,but i know that even on here there's been a few guys who've had issues with their transmissions slipping or acting funny after doing the fill procedure with the truck level,and after they've re-done the fill procedure with the pan rail level,their issues have gone away. Owning both a car 8 speed and a truck 8 speed,i know for a fact the car will take more fluid then the truck will if both are sitting level,as the cars transmission sits virtually level to the ground when all 4 tires are on the ground,while the trucks transmission has a very noticable downward angle to it with all 4 tires on the ground,and the fill plug is closer to the back of the transmission then it is to the middle or front of the transmissionQuestion for you...do you happen to know, did the transmission ship to you with any fluid in the pan? Since that green document is shipped with new transmissions, is it possible that leveling the transmission upon first startup is to fill areas/ports, etc that may have been drained prior to shipping? We all know that doing a normal drain/fill yields a fair amount less fluid upon draining than the transmission actually holds (not to mention the lines to the trans cooler). Seriously, I'm trying to understand why ZF would have different instructions and my working theory is the fill instructions are different for new/replacement transmissions than for maintenance drain and fills.
