RICHARD JOHNSTUN
I have a 4.7 motor Ram 1500. I have just dumped thousands into a new Jasper engine and then "suddenly"had to get new tranny from AAmco. They conned me to getting a different computer first, then the engine. I don't know what all they carried over in parts from old engine to new, because they "don't remember" Now it won't shift from 2nd to 3rd while going uphill at fairly strong throttle. shifts fine at flat ground or smaller elevation. AAmco tells me everything is fine. no codes so nothing wrong.... Until I took him on ride to show this problem. If I recreate for him, it doesn't shift, and will flash engine light when rev gets to about 5500, and engine sounds like it will explode. If I let off throttle enough, it will shift to 3rd and move on. The flashing engine light doesn't stay on. He said some control module on engine tells when to shift, but he doesn't know what it is called, and tells me he will research but never comes up with answer. so tired of paying through the nose for diagnostics and other leaks with engine and tranny, especially when I am unemployed because someone ran me over when I was walking and nearly killed me.
Engine shop says tranny problem and tranny shop says engine and neither will do anything without another fee... Any ideas on what control module I should replace...
