TufTruck 1210 vs 1223V
pacofortacos
You might want to check to see how high the front is raised - in particular, look at the angle of the front drive shafts if you have 4WD as if they get to too much of an angle they will wear out quickly.
The 1223VT's will act like stock springs for the first 2-3" drop then firm up to close to the 1210's range - and should give you 1-1.5" rear lift.
star_deceiver
Airdrie, Alberta
3.6 Pentastar
The 1210, 1211, and 1223 will all sit the same as stock. If you’re levelled and you put weight in the back you will get squat. Pick what you want: level when unloaded or level when loaded.
Here's 700lbs of quad with 2 full 5gal jerry cans and ramps with another 170lbs of tongue weight and no squat with a stock front suspension and 1211's in the rear.
