Uconnect audio static
mohammad alalawi
Kuwait
Hello,
I am experiencing sudden static in my audio when connecting to uconnect bluetooth. The problem is obviously from uconnect and not from the phone because i have tried other phones also. The issue resolved by itself for a while after restarting my car but reoccured again and now it wont go away. Can anyway help me out with a solution?
Thank you.
canadiankodiak700
Northern Ontario, Canada
3.7L Pentastar
There's a very good chance that you have a loose ground in your vehicle. More precisely, somewhere within the charging system. Make sure you're grounds are tight from your alternator. Your battery to the body from the engine to the body. Make sure your uconnect radio mounting bolt and the rear is mounted securely as that acts as a ground. Since you said it temporarily went away, I'm thinking that it is probably most definitely a loose ground and that it might have shifted enough to get a good ground again for a little while.
Ftank
