When you think of the perfect step bars for your Dodge Ram, you want them to give you a convenient, no-slip step, retain maximum ground clearance, protect the sides of your rig, and look stylish. RBP step bars match all these requirements.
They feature a one-piece welded steel construction and patented mesh design. The paintable, textured inserts allow you to customize your steps and make the set truly your own. They include all the needed mounting brackets and an instructions manual and are easy to install.
Step up into your Ram in style with RBP Step Bars and save your money! Buy any RBP RX3 or RX7 Step Bars at the best value – 15% off the original price. This offer is valid until May 31, 2020. Prices are already reduced.
RBP® - 3" RX-7 Series Black Round Step Bars
Features:
- Designed to make it easy to get in and out of the truck
- Give a boost to your vehicle’s appearance
- One-piece welded steel construction for ultimate durability
- Wheel to wheel length design
- Paintable, textured inserts for a customized look
- Easy to install
- All mounting hardware and instructions included
RBP® - 3" RX-3 Series Round Side Bars
Features:
- Welded one-piece construction
- The RBP logo is laser cut into the diamond plate step pad, and it is removable for custom paintability as well
- Easy Installation
- Paintable insert
- Body mount
- 3" main tube, 2.5" rung tube
- .84 gauge steel walls
- 16 gauge steel tube
- RBP metal badging
