If you want to improve your Ram’s visibility at night and make it look cooler during the day, you need LED Grille, and aFe has the perfect option for you. Their Scorpion Series LED Grille will give your ride a rugged new appearance that is sure to catch a few glances. This grille features heavy-gauge steel construction, CREE LED lighting with die-cast aluminum housings, two-stage powder-coated finish, and no-drilling installation.
Customize your Dodge Ram the way you've always wanted with aFe Scorpion LED Grille! This fall, you have an opportunity to save 20% on aFe Scorpion Grills. The offer ends on November 30, 2020. Prices are already reduced.
aFe® - Scorpion Series Tread Design LED Grille
Features:
- One-Piece Laser-Cut Design
- Two-Stage Powder-Coated Finish
- Built-In LED Lighting
- Stainless-steel hardware is included to provide the best corrosion resistance possible for each application
Includes:
- 1-Pc main grille
- Military-grade wiring harness
- Stainless steel installation hardware
