Verdict still out
I84885
I have read many post on lowering my ram 1500 wth the beltech 2/4 drop kit. Well I finally had the 963 ND kit installed on my 2017 ram 1500 big horn and I must say I was truly impressed. No rear wheel centering issues. I drove over 30 miles averaging 80MPH NO rear end wobble what so ever. It's been about 2 weeks now but so far so good. So I guess I will keep my fingers crossed also its a crew cab
I
I84885
1SloRam
Ms
Okay, I’ll bite. Let’s see this centered rear wheel with no brackets or adjustable arms installed.
1SloRam
Ms
Select attach files OR tap the little frame icon by the chain links.5721FCD9-A5E8-45B1-AC5C-F0D67D1D75DE.png
Administrator
Can't upload any pics. Do you have any suggestions
Are you getting an error? If the file size is too big it won't upload but it usually will state as such.
Administrator
THANKS FOR THE HELP IT WAS A RESIZING ISSUE
FYI, you can have multiple pictures in each post, it's the file size of each picture that's limited
Bigskyroadglide
Montana, except for work
Hemi 5.7, supercharged
I can't see you rear control arms real well, but they look like they are pointing down and are not parallel to the ground
If they are pointing down and not parallel to the ground, despite the look the wheels are not centered
That wheel doesn't look centered to me,it's pulled towards the front. It's impossible to go that low with a 4th Gen with-out pulling the wheels ahead. As stated by BigSky there's no way your locating arms are parrallel either,which can cause issues with a high speed sway,and throws your pinion angle out of alignment.
I
I84885
if its off centered it must have always been and if so its not by much maybe millimeters. I will measure it tomorrow just for curiosity.
