crxlvr
Ok so when I bought my truck I had the check engine abs and brake lights on with no working speedo. So I changed the vss two times, first a Dorman brand, then standard. Still the system worked intermittently after that.
Now my speedo will only work if it's raining outside, all 3 lights are still on on the dash. The speedo will never work in dry conditions anymore. What else can fix this.
